'89 780 - blowing headgaskets
Old Dec 7, 2005 | 05:18 PM
780 Freak's Avatar
Default '89 780 - blowing headgaskets
New guy here. I have an '89 780 Bertone with a B230F 4cyl turbo over 200K. I love the car but this will be the third head gasket in about a year and a half. WHY? All work was done correctly and the head was torn down and rebuilt by a professional who said the head was not damaged or warped. Will be going with an Elring set from FCP this time. Hoping you guys can help me troubleshoot.
Old Dec 7, 2005 | 07:09 PM
Default RE: '89 780 - blowing headgaskets
Sounds like something in the cooling system isn't working properly.
Old Dec 11, 2005 | 11:55 PM
780 Freak's Avatar
New water pump, fairly new radiator. Temp would go half way and no more after second HG. Would a bad turbo blow gaskets? What about torquing? Manual says to torque 3 times - the last time all bolts go 90 degrees. I snapped one doing this so only torqued to about 100. One thing I did not do is retorque. Tried that last week (after gasket blew) and 2 or 3 were a tad loose.
Old Dec 12, 2005 | 09:03 PM
You need to follow the torque specs to make sure it doesn't blow. If you have a problem with them breaking then buy new headbolts.
Old May 23, 2012 | 12:55 PM
icthus's Avatar
Always buy new head bolts after removing them. they have a "stretch" tolerance and truly can be torqued once. I've replaced a many heads on many different makes and models. All had new bolts and no returns.
Dads850
Jan 14, 2008 10:41 AM
marshcat
Jan 14, 2008 09:14 AM
pierre
Oct 20, 2007 07:37 PM
Pteezy
Aug 14, 2006 01:02 AM
pincky
Jun 20, 2006 02:24 AM
