92 960 sunroof leaking
Old Nov 26, 2008 | 05:50 AM
yamarx1's Avatar
Default 92 960 sunroof leaking
Never had a problem until it turned colder ( snow )now I have a wet headliner. Where does the water drain from the sunroof ? Possilble that the drains are clooged ( frozen ).
Thanks
Old Nov 26, 2008 | 07:36 AM
Default RE: 92 960 sunroof leaking
Check where the bolts go to hold the glass on and see if the metal there is corroded if so then the glass seal is bad.
It is usually easier to replace the glass then to fight with installing a new seal.
Old Nov 26, 2008 | 05:15 PM
yamarx1's Avatar
No glass on this model has metal sunroof
Old Nov 26, 2008 | 10:01 PM
OK then the drain hoses are on each corner of the assembly. With the roof open you can see the front drain holes but not the rear ones.
rspi
Mar 6, 2024 01:59 AM
jbarker2000
Sep 26, 2010 10:05 AM
Athilla
Feb 23, 2009 09:44 PM
Marks 240
Dec 16, 2008 06:04 AM
padover
Jun 26, 2008 10:08 AM
