'95 960 3-1-4
Old Aug 5, 2009 | 10:12 PM
hernando2170's Avatar
Cool '95 960 3-1-4
yup, got a hard fault with this code. thats good. keeps my check light on and no erase. symptom: intermittent bogging down (attempting to accelerate) between 1000-2000 rpm (usually at a light or complete stop) runs like a top after passing 2000 rpm. inspected wiring, no issues noted. Is this usual symptoms for a failed cam pos sensor?
Old Aug 6, 2009 | 10:40 AM
Default found prob- kind of
pulled cam pos sensor plug, found it bad, pins shorting to eachother, cover came right off, inserted sensor pins into car side and made a cover, and secured. code cleared and check light went out. still have my issue with hesitation/bogging between 1k-2k rpm. i found my cruise cntrl vaccuum pump cable missing/broke (aft of throttle cntl) i really dont think that has anything to do with it. ideas?? no faults noted. plugs? coil? injectors? im gonna pull the intake tube from the air cleaner to throttle, n clean that.
LOVEvolvos
Apr 23, 2011 03:52 PM
