Coolant Sensor Light
Old Feb 12, 2009 | 06:19 AM
jsmoline's Avatar
Default Coolant Sensor Light
Hello,
I have a 97 960 sedan with a 2.9 engine. The coolant sensor light goes on and off while the coolant level seems to be fine. Any ideas on this one?
Thanks, John
Old Feb 12, 2009 | 06:46 AM
Somthngfrce's Avatar
Sounds as if your sensor might be going.... I would replace it, since that's an easy one and see what happens!
Old Feb 12, 2009 | 06:54 AM
jsmoline's Avatar
Where is that sensor located?
Old Feb 12, 2009 | 07:16 AM
kzs983's Avatar
The coolant sensor it located under the coolant tank, where you top up the coolant. The tank should slide up off its brackets and there are two wires going in the tank at the bottom. If you tug on it gently the sensor should slide out, its about 3"long.
Old Feb 12, 2009 | 08:14 AM
jsmoline's Avatar
Hi again,
The fluid level was a little lower than normal. ( just below minimum. ) Would the sensor react to this?
Old Feb 12, 2009 | 07:50 PM
kzs983's Avatar
Most likely thats why the low coolant light came on because the coolant level was below the minimun mark. Just keep an eye on your coolant level. It shouldnt need filled up very often unless there is a leak or gasket issues.
Old Feb 12, 2009 | 08:33 PM
jsmoline's Avatar
Thanks,
Are gasket issues a problem with these? Just wondering if I should keep my eye out for anything in particular.
Old Feb 13, 2009 | 03:41 PM
kzs983's Avatar
Its not a major issue with the 960. Things to watch for would be blue smoke, overheating and using up significant amounts of coolant even though there are no coolant leaks.
Old Feb 13, 2009 | 03:42 PM
kzs983's Avatar
oh yes and keep an eye on your oil, if you notice its a greyish color thats a sure fire indication theres a gasket problem. This indicates coolant has entered the oil.
Old Feb 13, 2009 | 04:46 PM
zmontgomery's Avatar
My coolant was a hair lower than it should have been and the light came on. I would just add a little bit and see if it goes away.
Old Feb 13, 2009 | 05:26 PM
jsmoline's Avatar
Thanks much. I always find great help here.
Old Jul 31, 2009 | 12:47 PM
chinkin's Avatar
Default This doesnt end :)
Here is my story....i had my ABS and check engine lights on and took the car to the dealer for diagnostics ( i have a 2000 V70 Non turbo) and $150 later he tells me i need to replace my ABS module and ECT sensor....His quote to do this close to $2K. In any case with the help from this and other forums i get the ABS module replaced for less than 500 and i am happy as can be...But wait the following day my coolant sensor turns on....i check my Coolant level and it is way down....there seems to be some leakage....take it back to the shop and he tells me my water pump is out.......C'mon now...
So i get the timing belt and water pump replaced for another $600 ( it was due i guess at 110K miles) and then i am happy..
But wait...the coolant light still turns on......Now even though the tank is full the light remains on...even though i did not have that problem before....
Any ideas why this could be happening??? Is it the Coolant Level Sensor? How can i test to make sure that is the problem and not some leakage??I did notice that the coolant level drop some ...
Appreciate your help...cant spend any more money
Old Aug 6, 2009 | 10:42 AM
puretartan's Avatar
Default Timing belt
HI THERE LOOKS LIKE WHEN THEY DONE YOUR WATER PUMP ECT THEY STRETCHED THE WIRE TO THE SENSOR,, WOULD BE THERE FAULT,
I HAVE JUST FITTED TIMING BELT TO MY V70 2001 AND HAD THE SAME PROBLEM STRECHED THE WIRE,, MY MISTAKE,, BUT IN YOUR CASE ITS THEM TO BLAME
HOPE THIS HELPS
COLIN
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
cisopen
Sep 20, 2010 05:25 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
