'95 960 wagon auto trans shifter problem
Old Apr 13, 2015 | 09:55 AM
southpaw47's Avatar
Default '95 960 wagon auto trans shifter problem
Haven't figured this one out. Can't shift into park position using selector. I can disconnect the shift rod and manually shift into park from below.
Might need an automatic transmission shifter gear selector. Just the part that protrudes above the console floor and makes the gear changes. Mine is falling apart and now I can't get it to shift into park. What surprises me is that I can leave it in neutral, shut it down and remove the key. Finally got the button on the grip to work but same issue. Any ideas?
Old Apr 13, 2015 | 11:31 AM
VDonkey's Avatar
Sounds like the cable (mechanical cable like a bowden or similar) is broken between the ignition lock and the shifter assembly.
xDread92x
Jul 21, 2019 04:18 PM
nortons
Feb 22, 2015 11:14 PM
LarryG1967
Feb 25, 2014 08:52 PM
VolPat
Jun 15, 2012 08:06 PM
gearhead4
Jun 14, 2007 02:52 PM
