960 head gasket install
You must make sure that the crank is on it's own timing mark, when done correctly, all pistons will be below the deck and will be out of the way of any valves.
To do so any other way could allow a valve to hit a piston as you bring the head top down compressing the valve springs before bolting.
Hopefully you marked the cam timing gears to their cams and marked which one was the intake or exhaust.
Try not to use those small head top bolt to bring down the head top, they will strip very easily, if you do, then you must turn all 40 something the same 1/2 turn to bring it down ever so slowly. I used 4 clamps like the other poster suggested.
DanR
DanR
shahid_zaman
06-21-2008 08:44 PM
