960 Rear ABS sensor location
Old Dec 8, 2010 | 12:21 AM
91shelby's Avatar
Default 960 Rear ABS sensor location
I have a 92 960 as a lot of you know and well the speedo bounces around alot. where is the rear abs sensor located? also which of the abs sensors runs the speedometer?
thanks
Old Dec 9, 2010 | 02:10 AM
91shelby's Avatar
anyone?
Old Dec 9, 2010 | 11:47 AM
dan550i's Avatar
I believe the sensor is located in the rear end.
And it is the same one for both systems.
The usual cause is the connector has some corrosion or has been knock by road debris.
Good luck
DanR
Old Dec 12, 2010 | 05:24 PM
91shelby's Avatar
my chiltons manual is saying to remove 2 bolts in order to lower the rear differential assembly, however i cannot determine what 2. does anybody have any advice on this. It looks impossible to get the rear abs sensor out without dropping the diff assembly
Old Dec 12, 2010 | 05:29 PM
I have removed them without dropping the diff. It is a pain but can be done. Check the plug for the sensor. It uses the same connector type as the ones for the coil packs.
Old Dec 12, 2010 | 07:12 PM
91shelby's Avatar
i can see it but cant access it
Old Dec 12, 2010 | 09:34 PM
Yes it is very tight. I usually use long 90 Degree needle nose pliers to grab and slide the plug up. I use a small screwdriver to lift the tab up for the plug.
Old Dec 12, 2010 | 11:23 PM
91shelby's Avatar
how do you get the plug out so it can be cleaned etc?
Old Dec 13, 2010 | 07:42 PM
With the long 90 Degree needle nose like described above.
Old Dec 13, 2010 | 09:13 PM
91shelby's Avatar
i will give it a shot thanks! How do you drop the rear axle any way..?
Old Dec 15, 2010 | 06:49 AM
urbs4's Avatar
i needed to change mine too, and wrestled with how to reach it, I just could not figure out how to get at it while laying on my back, and it was in such a tight location. I ended up using a dremel cutting tool in the trunk to cut an access panel. I had to remove the trunk carpet and there are some carpeted panels that had to be removed as well. Once the panel was cut out - i had easy access to the abs sensor. I just eyeballed the approximate location of the sensor when i was marking the area to cut. Hope this helps if you determine you can't get to it any other way.
duckland23
Apr 30, 2014 10:03 AM
sjbyy520
Jul 24, 2011 06:48 PM
solaide
Jan 27, 2011 01:52 PM
sabydady
Jul 7, 2009 04:58 PM
rich nc
Jan 18, 2009 01:36 PM
