960 rear end shudder?
Old Dec 11, 2006 | 01:22 AM
92volvo960's Avatar
Default 960 rear end shudder?
Well my 192 960 has hit 220k and is running awesome. There is only one concern i have. When accelerating from a dead stop i can feel a shudder coming from the rear end (i think its the rear end). Its only shudders for maybe the first 15-25 feet i accelerate. Its not getting any worse as i add the miles on, but it is getting a little annoying. Just wondering if this a common problem and what it might be.
Old Dec 11, 2006 | 08:56 PM
Default RE: 960 rear end shudder?
Usually that is from a worn/misaligned driveshaft carrier.
It is the bushing/bearing that is mounted to the plate in the middle of the driveshaft.
Old Dec 12, 2006 | 11:50 PM
92volvo960's Avatar
Thanks ill have to check that out at work one day. I would think that would cause a shuddering at most speeds though, instead just a few feet or so. Either way ill check it out. Thanks again.
Old Dec 13, 2006 | 12:15 AM
Also look good at the angle of the driveshaft at the mount.
I have had to adjust the bracket with washers to stop the shuddering.
I installed the washers between the plate and the bearing assembly.
Old Apr 3, 2012 | 02:55 AM
hutenant's Avatar
Any new news on the shuttering problem ? As I have the same problem though it also happens particularly when going up hill from a stand still, it feels as though the rear end is going to fall out.
Old Apr 3, 2012 | 11:54 AM
red7218's Avatar
Talking Wheel hop?
Mine does it too when I really get down on it hard, especially in the rain......
cbatterman
Apr 9, 2014 06:09 PM
ylwgto
Dec 8, 2012 12:41 PM
TonyS
Sep 21, 2011 10:32 PM
netweaver
May 7, 2010 01:26 AM
Bruno937
Mar 8, 2009 12:41 PM
