Will a 940 rear end fit a 240 rear end?
Old Mar 6, 2009 | 08:49 AM
Bruno937's Avatar
Default Will a 940 rear end fit a 240 rear end?
I have a 92 240 wagon with a noisy rear, possibly worn rear end bearings. Should I try to get it fixed or change the rear with a used one. Someone has a 940 rear for $150 and my friend can replace it for free. That is if this rear fits. What do you think?
We bought this car to donate to a local widower in need and any help will be appreciated. We have to do a few more repairs on the car and the budget is tight.
Old Mar 6, 2009 | 10:32 AM
TIPSP's Avatar
Got Boost?
It should fit. Is it a 1031 or a 1041?
Wait for the experts.
Old Mar 8, 2009 | 10:32 AM
SR Heer's Avatar
Default Volvo rearends
How can one tell if it is a 1031 or 1041 and are all the 240 sedan and station wagon rear ends the same gearing? what about the 90 - 240 rolling chassis sedan that I am thinking sticking the 2.4N/A Diesel VW engine along with it corresponding sedan standard transmission in chassis - will I have to change out the rear end ? or are these the same and how might I tell? Is it easier to just change out the gear/cluster verses whole rear end?
Thanks
Stephen
Old Mar 8, 2009 | 12:41 PM
TIPSP's Avatar
Got Boost?
I believe wagons came with 4.1 from the factory, while the other models got 3.9, 3.7..etc. There is a label on the axle. If the rear end is covered in grime and Sh*t, it will have to be clean first to see it. You should be able to use the same rear end, but you might need a custom driveshaft.
87 740 turbo wagon
Feb 20, 2014 08:50 PM
roamer
Jan 16, 2010 06:34 AM
Ryguy
Nov 17, 2009 06:31 AM
cimeron
Jan 13, 2008 10:37 PM
jloco
Sep 22, 2005 10:20 PM
