97 960 Cylinder Order
Hey guys I'm doing a coil a new coil on the number 4 cylinder. Its the inline 6 cylinder that came equipped with the 960's for this year. Is the order for the cylinders 1-6 from the front of the engine to the rear or does it go 1-6 from the rear of the engine to the front? Just being sure I'm swapping the right one. Thanks in advance...
Josh
Josh
Thanks man...I swapped the 3 and 4 coils cleared the codes and drove around till it threw another one and this time it said misfire cylinder 3 instead of the previous misfire cylinder 4 so it's no doubt a coil problem with number 4. Thanks for the help bro...
Josh
Do you guys recommend swapping that plug since its been getting sprayed with fuel and not igniting?
Josh
