960 electrical mystery
Old Feb 3, 2007 | 08:22 PM
jonemory's Avatar
Default 960 electrical mystery
my car has a problem with killing batteries... it shows that my alternator is putting out only 7.4 volts out of a 15.5 it used to put out... i took it out to get a new one.... also my check engine light has a code for my coolant temp sensor... the problem will not go away.. i tried a new sensor didnt work.. what should i check... could it be my cooling fan relay... my fan comes on right when i turn my key to the on position and wont go off until it thinks it should... it makes my car run rough when its cold because my whole motor thinks its hot and its not.. any help would be appreciated..
Old Feb 3, 2007 | 08:53 PM
Default RE: 960 electrical mystery
Replace the coolant temp sensor and thermostat.
Old Feb 3, 2007 | 09:46 PM
jonemory's Avatar
i have done that also... still the same thing.... i have checked the resistance on the sensor and it checks out with the chart. could it be a bad wire...
Old Feb 4, 2007 | 05:29 PM
It could be. Or a bad relay and it is sticking on.
HoundWisper
Dec 8, 2013 01:06 AM
Anomorato
Sep 11, 2012 05:40 PM
xpiecemealx
Nov 9, 2010 08:56 AM
nsimha
Aug 11, 2007 07:36 PM
