97 960 rear shock spring setup identification
Old Jun 15, 2023 | 11:10 AM
orion42m's Avatar
Default 97 960 rear shock spring setup identification
Hi folks,
I'm trying to identify the rear shock set up on this 97 960. It’s been in my family and we are the original owners and I have not found anything in the repair records that indicates that it was converted from a Nivomat set up and it only has 30k so I’m thinking it was the original set up, pushing down on the rear end and the car bounces around a bit so the shocks need to be replaced. Anyone seen this type of set up on a 97?
Prior picture was incorrect and was of front strut, and have uploaded the correct one now
Turns out the rear shocks are and they are leaking:
SACHS BOGE
54 1700 124 371
VOLVO
9169420
6992
Made in Germany
XP
Any recommendations for replacements? Nivomat (if I can find them) or some sort of coil over?
Old Jun 21, 2023 | 09:25 AM
Dingus1's Avatar
https://www.rockauto.com/en/moreinfo...t=7556&jsn=840
If it helps in your search, the 9169420 is the OE number. I looked at 2 sites and the original is discontinued/ out of stock.
Old Jun 21, 2023 | 11:01 AM
That's a regular gas shock. If you put nivomats on that will jack the back end of the car up. Nivomat cars use a lighter spring. (I trust the rear end of the car is not sagging)
Here's the parts page - and they appear to be out of stock everywhere - Except Voluparts.com in Atlanta 404-352-3402 They have a pair - Unfortunately they want $319 for the pair.
Old Jun 21, 2023 | 12:10 PM
orion42m's Avatar
Thank you, yes on my initial search they did seem to be out of stock in most places.
I also ran across 271899 referenced at volvo.oempartsonline.
Also KYB GAS-A-JUST KG5565 on Amazon and a comment on reviews but did not confirm vehicle :
"The thing actually fit after drilling out the bottom attachment point"
Another reviewer said it did not fit their 960 sedan:
"Doesn't fit my 1994 volvo 960 sedan as bottom hole is 12 mm not 14 mm as required"
So I am wondering if opening the bottom attachment point would work.
I still have to compare if the other specs will work.
KG5565
Part Type Shock Absorber
Bump Stops Included YES
Bump Stops Included NO
Position Rear
Upper Mount Type E2(12.2X54.8)
Lower Mount Type E2(12.2X54.8)
Compressed Length 12.17
Dust Cover Included YES
Extended Length 18.54 in (470.916 mm)
Stroke Length 6.38
Body Type Various - Application Specific
Manufacturer's Part Number: KG5565
Shipping Weight: 3.76
Package Height: 21.1
Package Depth: 2.9
Package Width: 2.8
Part Category: Performance Parts
Part Fitment: Direct Fit
TomT
Mar 10, 2011 11:14 AM
91shelby
Sep 14, 2010 06:47 PM
ziphius
Apr 27, 2009 01:12 PM
SER
Mar 21, 2008 09:58 AM
morenc00
Feb 27, 2006 10:37 PM
