98_V90: Right Brake Light, bulb and socket good
Old Jan 6, 2016 | 10:36 PM
Backbutton's Avatar
Unhappy 98_V90: Right Brake Light, bulb and socket good
On 1998 V90, in AM, nothing happening overnight, the right (passenger side) brake lamp went out, but the running lamp is lighted. Two filament bulb--lower lamp--running and brake light combined. Dash warning light is on.
Replaced bulb twice, swapped lamp plug with driver's side to confirm it was not the plug.
Inside of lamp housing is clean--although some years ago, had shorts when car was washed, fixed with caulk on the lens.
Had happened last year, changed some bulbs then went away. But not this time.
Any suggestions or help will be appreciated.
Old Jan 15, 2016 | 02:57 PM
VDonkey's Avatar
If you don't have the wiring diagrams for your car, let me know in this thread and I will give you a link.
Old Jan 17, 2016 | 12:43 AM
Backbutton's Avatar
Default Problem solved for now.
Was driving me nuts. Thought I got it finally fixed after changing both left and right bulbs with new, sanded and expanded the contacts. Finally, both worked.
I put the access covers back on--had to pound a bit, and right light went out. I played with it--it came on, but left brake light went out. I played with that, and it came back on, but right brake light went out.
Finally, in frustration, I took the right brake socket and twisted it back and forth, just for the heck of it, since I was out of ideas. It worked. So it was a contact problem.
I bought two new sockets, but ended up not using. I have 10 bulbs now too.
Old Jan 17, 2016 | 12:48 AM
Backbutton's Avatar
Default Thanks.
I don't have the wiring diagrams.
I am not that good with wiring diagrams. But I had fixed my power window master switch and hazard blinkers.
I went to Auto Mechanics school one summer while at college. The instructor said, if you understand wiring diagrams, you've got it solved--but if someone wants an electrical problem solved, don't do it in 5 minutes, take a nap, and then charge him/her for an hour--damn crook--but it is true.
londe
Mar 3, 2019 07:19 PM
londe
Mar 27, 2011 01:36 PM
chef
Feb 2, 2011 01:47 PM
bond007
Jan 30, 2011 09:54 PM
bobschwind
Apr 8, 2009 09:25 PM
