blow by
RE: blow by
ORIGINAL: volvogirl123
Okay, sorry to sound stupid, but I'm curious. What the heck is blow by?
It's ok
It's no biggie
The blow by is simply an unburned mixture of fuel and air. When your engine's piston rings or cylinders are worn out, unburned mixture of fuel and air accumulate in the crankcase. That mixture can cause the oil quality to depreciate, which in turn results in poor lubrication and again unburned mixture of fuel and air.
In order to check, you can drive your car and park it at a safe place, open up the oil filler cap with engine running, if you see some smoke, it's a blow by.
