Blow-off Valve
Old Jul 11, 2005 | 10:33 PM
JohnS4's Avatar
Default Blow-off Valve
My brother just got a 2005 S60R. We are going to start modding it immediately and I was wondering if anyone has put and aftermarket blow-off valve in a S60R yet?
Old Jul 14, 2005 | 03:17 PM
JonnyEnglish's Avatar
Default RE: Blow-off Valve
I was wondering the same thing myself any help appreciated
JonnyEnglish
Old Jul 24, 2005 | 03:46 AM
robert213's Avatar
Usually Blow-off valve is not needed, unless running above factory boost levels and you hear squawk/gobble-like noise from turbo stalling between shifts.
TurboXS Type H is nice, because you can install as bypass-valve (reroute air back into turbo inlet) or install as blow-off (into atmosphere).
Old Jul 30, 2005 | 02:01 AM
Turbo5's Avatar
you do not want a blow off valve on a volvo car, you will be venting air that has already been computed into the engine management system, and it will make your car run crappy, i had bad experience with that, you will do fine without one, i can hear my car between shifts from an eigth of a mile away
Old Apr 7, 2007 | 12:28 PM
Catchincotton's Avatar
Here is the write-up on what I did!
It didn;t throw any code or anything like that!
The Car Runs fine and Sounds great I have an HKS SSQV on a 2005 S60 R
http://volvospeed.com/Mods/bov_s60r_volvo.html
Later
Cotton
Old Apr 7, 2007 | 12:33 PM
S70driver's Avatar
Yes you can run a BOV. I wouldn't suggest a TurboXS of any kind. They are prone to leaking. I do suggest getting an HKS SSQV.
I would also run a blanking plate as well. This replaces the factory CBV and the vaccum line that is running to the CBV is then routed to the BOV. QuickBrickMotorSports sells the blanking plates.
You may run a little rich after the BOV goes off. If your automatic you will only hear the BOV go off when you take your foot off the gas. From what I have heard if you have the Triptronic gearbox and put it into the fake manual setting you will not hear it go off inbetween shifts.
Turbovolv85023
Jan 3, 2008 08:13 PM
Tony_S70_99
Jan 21, 2006 05:29 PM
NFSS40
Oct 8, 2005 02:53 AM
Tony_S70_99
Jul 21, 2005 11:13 PM
cecilvaliant
Jan 27, 2004 04:41 PM
