classic no start 760
Old Nov 6, 2014 | 11:43 AM
grindstone's Avatar
Default classic no start 760
1990 760 started to stall out [ sudden tach drop] after a 30 min drive .it will restart after sitting for 5 min but only run for 1 i can here fuel pump on start up ,replaced crank sensor ,switched suppression relay all grounds are good as are positive leads , coil tests good ,with an ignition tester on when running i can tell an instant spark loss ,followed by no spark when trying to restart , now the weird /when it dies i have no spark while cranking but when i release from cranking i will get a spark ,but none on crank it is almost like the old dodges with a ballast resistor when running the car performs to expectation , and is well maintained .after awhile sit for 5 drive for 1.parts are hard to come by where i am so test procedures are welcome ,can a fuel pump relay cause no spark?
Old Nov 6, 2014 | 09:16 PM
grindstone's Avatar
Default figured it out by luck
it is the ignition amp ,if i shake or bang it i can shut the engine down ,it seems like the male end of the module is faulty
Jim W
Aug 18, 2009 06:17 PM
samepartlee
Sep 12, 2008 08:16 PM
samepartlee
Aug 21, 2008 10:55 AM
Aeisner
Feb 16, 2007 10:13 PM
pznuttz
Mar 6, 2006 02:47 PM
