cold starting
Old Oct 26, 2005 | 08:20 AM
web1275's Avatar
Default cold starting
My 1989 760 turbo 2.3inj is difficult to start when cold it starts first time every time when warm but when left over night it has to be coaxed into life i have to turn the key and let the engine crank a couple of times and it tries to fire but if it does not catch straight away it does not fire anymore no matter how many times i let it crank over ,if i switch off again and crank the same thing happens if it does not catch on the first couple of cranks it is a waste of time as we are heading towards winter here in the uk i thought i had better try to find out what the problem is and rectify it (hopefully) once it does eventually start (if the battery does not give up first) it runs fine no spluttering misfiring smoke or anything and will start for the rest of the day as good a gold.
any ideas ?
thanks
webster
Old Oct 26, 2005 | 08:47 PM
Default RE: cold starting
Has the throttle body and idle motor been cleaned lately?
Have you checked fuel pressure yet?
If not then start with those 2 things first.
Dennis Bor
May 30, 2011 11:14 AM
arttu
Feb 15, 2007 10:16 PM
Athilla
Dec 26, 2006 10:20 PM
mjv4998
Jul 27, 2006 01:57 AM
spyder
Mar 18, 2006 12:36 AM
