door lock
Old Dec 22, 2005 | 10:51 PM
cool_kyle_3000's Avatar
Default door lock
my 1988 760 sedan turbo has power locks but the one on the drivers side doesnt work. any one know how to fix and or replace it?
Old Dec 22, 2005 | 11:03 PM
Default RE: door lock
Its really not that bad once you get the door panel off.
Old Dec 30, 2005 | 09:37 PM
i stick in the key and it wont turn in the lock
Old Jan 2, 2006 | 12:04 AM
Is it like ther rod isn't hooked up or like it is seized?
Old Jan 4, 2006 | 05:56 PM
the key goes in fine but it just wont turn it was fine then all of a suddon it didnt work so now i can only opent he passenger doorjavascript:void(AddText('[:@]'))
Old Jan 4, 2006 | 09:35 PM
First thing to do would be remove the door panel and disconnect the rod from the lock cylinder then try. If the key move good then the lock assembly is bad. If it still wont move then the lock cylinder is bad.
Lgbpop
May 26, 2021 03:34 PM
qcvol
Jun 17, 2013 09:55 PM
crgolf
Feb 10, 2013 12:43 PM
rcvolvo
Jun 3, 2012 02:25 PM
cganotisi
Sep 22, 2006 01:20 AM
