Driver brake light socket is partially melted. Why?
Old Mar 26, 2011 | 01:08 PM
londe's Avatar
Default Driver brake light socket is partially melted. Why?
I know this is not a V90 forum, but the 960 wagon is similar to the V90 and members may have experiences this problem. The dashboard bad bulb warning light turns on when I step on the brake pedal. The driver's brake light is weakly lit and the plastic portion of the brake bulb socket was partially melted. Does anyone have an idea why this circuit is drawing so much current that it is melting the plastic? Reseating the brake bulb in the socket fixed the bad bulb light and corrects the dim light. Thanks in advance.
Old Mar 26, 2011 | 03:45 PM
It may be a common design problem. But make sure it has the correct bulb installed.
Old Mar 27, 2011 | 01:40 PM
londe's Avatar
Default re bad bulb
Thinking that a poor connection was the culprit with increased resistance generating head, I cleaned the connection and applied a dilectric grease. The bad bulb problem is solved. thanks
Old Mar 29, 2011 | 09:10 PM
swiftjustice44's Avatar
Your thinking is correct. Furthermore, Volvos seem to be particularly sensitive to excess heat from the 2 series through to the 9 series. Brake lamps, particularly w/ automatics, get HOT. Sitting in traffic with one's foot on the brake generates a lot of heat. Additionally, previous owners may have installed higher wattage bulbs, vainly attempting to get brighter lamps or just ignorant.
Old Mar 3, 2019 | 04:28 AM
240VolvoinDC's Avatar
I have the same issue on my 240... one option is to upgrade to led bulbs. They create less heat
Old Mar 3, 2019 | 07:19 PM
lev's Avatar
lev
After market lights seems less tolerant to heat. But I have seen both kinds with melted plastic, usually at the brake bulb, logical since many drivers ride the brakes. Sometimes housings are fixable with a grinder, getting the holes back to the right shape.
Greenmudshark
Mar 23, 2012 06:37 AM
londe
Mar 27, 2011 01:36 PM
b1gn3ll2011
Feb 20, 2011 10:11 AM
JJR
Jul 19, 2009 09:17 PM
ciao-rich
Apr 22, 2006 05:04 PM
