fuel sender unit line digram
Old Sep 9, 2014 | 07:08 PM
blkman59's Avatar
Default fuel sender unit line digram
I have a 1995 Volvo 960. I remove the fuel sender unit and can't remember where all the line reconnect to, I need a diagram of where all the rubber hoses go to from the fuel sender unit. It is a sedan model, can someone help me?
Old Oct 7, 2014 | 11:15 AM
240 Guy's Avatar
I am not familiar with the details of the 960, however, usually there are two fuel lines, the pressure line to the fuel injectors and the return line. The return line is usually smaller diameter. I am guessing from the question that there may be more. So, you may also have a evaporative emissions line that goes to a charcoal collector.
The pressure line connects to the output of the fuel pump, the return line goes to a tube that goes to the bottom of the tank and usually has a rubber duck bill on it. The evaporative line goes to the top of the tank to take care of the vapors.
fochs
Mar 10, 2015 06:42 AM
Mr diy
Nov 23, 2014 04:43 AM
metalslug
Mar 23, 2010 07:17 PM
rationull
Dec 16, 2006 11:21 PM
penkogj
Nov 19, 2006 11:49 AM
