Leak on fuel sender housing
Old Nov 17, 2006 | 04:40 PM
penkogj's Avatar
Default Leak on fuel sender housing
I have a 89 740 GL which is leaking fuel at the fuel sender housing. The leak is at the nipple of the lowest of the three hoses attached to the round cover (not including the filler hose). Does anyone know the position of pressure and return lines at the cover so I can identify which is the leaker? Does the fuel sender need to be removed and repaired or is it possible to clean and seal the leak with a suitable gasoline resistant sealer without removing the unit? Thanks for any help.
Old Nov 19, 2006 | 11:49 AM
Default RE: Leak on fuel sender housing
I would just try to find a used good unit and swap it out.
gibbster
Oct 21, 2012 02:56 PM
NHW
Sep 21, 2012 09:16 AM
melancthon
Dec 17, 2010 04:37 PM
metalslug
Mar 23, 2010 07:17 PM
rationull
Dec 16, 2006 11:21 PM
