Idling Rough, Gaining and Losing Power
Old Feb 16, 2007 | 12:40 AM
DACouture's Avatar
Default Idling Rough, Gaining and Losing Power
I'm pretty sure I have an idea as to what the problem is on my 1992 960 however I would like a second opinion from an expert in here if possible. I just noticed today as I was driving that the engine was idling real rough and a lose and gain of acceleration as I was driving. When I got to my destination I opened the door and it sounded as if I had an exhaust leak. I think my Cat may be backed up and or losing power form the leak if this is what it is? Does this sound right? if so any ball park figure on how much a repair like this would run for one of these cars?
Thanks in advance,
David
Old Feb 16, 2007 | 12:48 AM
DACouture's Avatar
Default RE: Idling Rough, Gaining and Losing Power
in addition it has been very cold here lately almost artic reading now higher then 32 degrees and as cold as -15.
Thanks Again,
David
Old Feb 17, 2007 | 02:06 AM
Could be misfiring.
That sometimes makes it sound like an exhaust leak.
Old Feb 17, 2007 | 03:49 AM
DACouture's Avatar
would a simple tune up correct a misfiring problem if that was the case?
Old Feb 17, 2007 | 11:14 AM
Maybe depends on how old the cap,rotor, and wires are.
Old Feb 18, 2007 | 12:32 AM
DACouture's Avatar
not really sure bought the car used but I do know at 125,000 he timing belt snapped and the previous owner had about 5,000 dollars worth of work done to the vehicle. I was wondering if it is the exhaust what am I lookin at to replace this cost wise?
Thanks
Old Feb 18, 2007 | 09:41 AM
Is the check engine light on?
Old Feb 18, 2007 | 11:21 AM
DACouture's Avatar
yes I think the check engine light did come on
Old Feb 18, 2007 | 11:34 AM
Pull the codes using this method and it will help us help you get it figured out.
http://www.troublecodes.net/Volvo/
Old Feb 18, 2007 | 02:39 PM
DACouture's Avatar
I just did the codes and hopefully I did it right but I got a 1-1-3
Old Feb 18, 2007 | 02:42 PM
Means a vaccum leak.
Check all hoses really good.
Old Feb 18, 2007 | 02:45 PM
DACouture's Avatar
okay I'll check them out thank you
Old Feb 18, 2007 | 03:03 PM
DACouture's Avatar
UPDATE I also pulled a 1-2-2 code as well. it said it is the air tempature gauge faulty is this correct?
Thanks,
David
Old Feb 18, 2007 | 03:11 PM
DACouture's Avatar
I think my injectors are faulty as I continued to pull codes I pulled a 1-1-5 and a 2-1-2, this is what I get for buying a used car in a hurry, guess I'll learn later
Old Feb 18, 2007 | 03:34 PM
Clear all codes and Reset the computer buy unplugging it.
Then test drive and see what comes right back.
Old Feb 18, 2007 | 04:47 PM
DACouture's Avatar
okay well I cleared all codes like you stated and took it for a test drive ranging in mph from 15 to 50 after doing so I came back and pulled three codes 2-1-2, 1-1-3, and 1-1-5, I also notice a strong smell could is possibly be my O2 sensor is faulting causing to strong of a fuel mixture which is causingthe engine to run rough. As well when I accelerate sometimes it's bogged down and then picks back up and then boggs back down could this have anything to do with to strong of a fuel mixture?
Thanks for all the advice,
David
Old Feb 18, 2007 | 05:20 PM
  #17
DACouture's Avatar
almost forgot I am also still getting code 1-2-2
Old Feb 18, 2007 | 09:32 PM
  #18
Could be a bad Mass flow sensor,O2 sensor,or injector or ground for the injector.
Old Feb 18, 2007 | 09:44 PM
  #19
DACouture's Avatar
one thing I notice is that it doesn't give me a problem until it starts to warm up on a cold start it idles, revs up and runs fine do you think it could be the air temp sensor as I notice you stated in other post it will cause the car to run rough as well
Old Feb 18, 2007 | 09:58 PM
  #20
DACouture's Avatar
correction - coolant temp sensor I mean.
Thanks Again,
David
