Idling Rough, Gaining and Losing Power
Old Feb 18, 2007 | 10:17 PM
  #21
Default RE: Idling Rough, Gaining and Losing Power
If the coolant temp sensor was bad it would set a code.
Old Feb 18, 2007 | 10:24 PM
  #22
DACouture's Avatar
okay well looks like this is a mechanic issue as I am not one myself but thank you for all your advice what do you think would cause it to run fine though when at a cold start but then begin to give problems as it ran for a while.
Thanks,
David
Old Feb 18, 2007 | 10:37 PM
  #23
It could be many things.
The computer richens the mixture when cold then when it warms up it leans it out.
You may have a vaccum leak or something like that.
Old Feb 18, 2007 | 11:16 PM
  #24
DACouture's Avatar
well if I'm reading the code right it says injector number 1 is faulty how is the pattern of the fuel injectors on the 960 does it go 1 to 6 starting from front of the engine (ie where the radiator is) or does it go 6 to 1?
Thanks again as always,
David
Old Feb 18, 2007 | 11:22 PM
  #25
It should go from 1 to 6.
But the injectors are split.
1-3-5 2-4-6
They are in 2 circuits
Old Feb 19, 2007 | 08:35 PM
  #26
DACouture's Avatar
one more question have many o2 sensors does the volvo have my understanding there is one but I know some car models have one in front of the cat and in the back?
Thanks again
Old Feb 19, 2007 | 10:57 PM
  #27
I think the 1992 only has one on it.
I could be wrong the 92's don't come in very often.
REEL
Mar 2, 2013 10:01 AM
henryn
Jun 1, 2012 12:11 PM
bueff
Mar 8, 2011 11:23 PM
shepbomb
Dec 14, 2009 10:11 PM
Chart
Nov 15, 2008 12:26 PM
