Intermittent speed sensor test?
Old Feb 9, 2007 | 08:09 PM
red7218's Avatar
Default Intermittent speed sensor test?
Does anyone have a proven way to test this circuit on a 1996 960 wagon. Mine throws a PO500 code every couple of days.Thespeedo dies for a few seconds and then starts working agian. I hate to just start throwing moneyat a it.I suspect it could be a bad connection, but I can't figure out how to test this circuit while the car is sitting still, other than jacking it up and letting it run while I crawl under it.I guessI'm hoping apro might tell me how they would attackthis problem.Thanks RED7218
Old Feb 10, 2007 | 10:25 AM
Default RE: Intermittent speed sensor test?
Have you checked the wires at the Diff. cover?
You could jack it up and Ohm the sensor and spin the tires.
Old Feb 10, 2007 | 05:41 PM
red7218's Avatar
OK, I know it sounded like a dumb question.The 3 inchesof wiring I cansee looked fine.The manual statesthat you have to drop out thethird member to gain access to the sensor. 300-600 ohms. Ijust can't get to it.Does anyone know where theharness is routed or aplace to gain access to it withoutdropping the axle?A smart Viking would have put anaccess panelin the floor pan. Where's my saws-all
Old Feb 10, 2007 | 05:51 PM
Try to get the plug unplugged. The rubber around the terminal is known to fall apart allowing corrosion get to the terminals.
You can get to the sensor I do it all the time.
Old Feb 10, 2007 | 06:41 PM
red7218's Avatar
Thanks Ill give it a shot.
jonqu
Sep 4, 2013 12:45 PM
richsid
Mar 25, 2008 01:01 PM
willko1
Dec 13, 2005 01:38 AM
parrym
Nov 7, 2004 11:30 AM
