Just got a 960....1996
#141
Erase the code and see what comes back. While you have the motor open, it is a good time to clean (ultrasonic) the injectors. It is about $ 15-20 per injector.
#147
#148
OK...gonna do the seal....finally got back to the car after Halloween....i did however put it together 1st to see...and you guys were right on...it broke the seal....so now i guess i need to shop....
cam seals
timing belt
sealant for cam cover
bolts?
not sure where to get all this without killing my wallet...
and....i noticed when retightening the bolts, almost half were stripped, or almost..
how do i fix that? the bolts seem fine, its the aluminum that is bad....
cam seals
timing belt
bolts?
#149
cam seals
timing belt
bolts?
cam seals
timing belt
bolts?
Belt: Contitech (Continental): FCP/Tasca: $ 34
Sealant: Permatex Copper Spray (HG Seal, high-temp, etc) Napa sells, $ 10
Bolts: FCP, and/or Tasca: $ 40-50.
If threads in the hole are stripped, you need to tap them with thread repair.
#150
bluesb4sunrise
07-18-2012 12:57 PM
Ahmed
07-08-2012 04:08 AM
jersey girl
09-24-2004 12:37 AM
