New old '88 760 Turbo
Old Jun 7, 2014 | 12:08 AM
bentobox's Avatar
Default New old '88 760 Turbo
Hello everyone,
I just bought a 760 turbo. What a fun car! I will post pictures later, after I give it a good wash.
Right now, I'm giving it a tune up; oil change, tranny oil change, spark plug, etc.
I want to upgrade the fuel injectors but I don't know which ones to get, any ideas?
Old Jun 7, 2014 | 09:35 AM
lev's Avatar
lev
What's wrong with the injectors you have?
Old Jun 10, 2014 | 10:54 PM
bentobox's Avatar
Old Jun 16, 2014 | 04:28 AM
bentobox's Avatar
new injectors, @ lev; slight engine stumble at idle, i thought it was clogged injectors.
resistor bypass
Old Jun 16, 2014 | 12:12 PM
lev's Avatar
lev
Very little chance stumble caused by injectors... Do a good "tune up" first. New injectors are hugely costly.
Old Jul 22, 2014 | 05:57 PM
Cactuslegs's Avatar
Cleaning the throttle body is a cheap diy maintenance item that can have a big impact if it is nasty enough.
Old Jul 23, 2014 | 10:08 AM
bentobox's Avatar
I cleaned the TB and ICV, that helped alot. But there's still a slight hesitation at idle. I think it's because of a clogged cat. Also, I'm only boosting at 5 psi. I turned in the boost controller all the way in and even turned in the wastegate arm 2 turns, still 5 psi of boost. No boost leaks. Vacuum lines and hoses were checked and replaced.
No play in the turbo (Garret T3). I unplugged the bung before the cat and I think there was an improvement of 1/2 or 1 psi. I'm suspecting a clogged cat.
Anybody have this problem before? Low boost? How did you fix it?
wkdenton
Sep 17, 2014 07:52 AM
donf
Jul 5, 2013 02:52 PM
Red Tractors
Sep 18, 2012 01:38 PM
Cyclenby
Feb 14, 2011 11:02 AM
volvoyoungster
Feb 22, 2007 08:37 PM
