New to Volvos, witha few questions
Hi all. I bought my neighbors 93 960 wagon (156K miles). It was too nice a price to pass up. The 960 will be used by both myself and my mother in law when she drives my boys around after school. My wife won't drive it ~shrug~ Better for me.
I own a 02 jeep Wrangler so I am used to doing some of the work on my own vehicles. I have had 4 new tires and an alignment done already.
I know I need to do a brake job (soft feel when I depress the pedal) and an oil change on the 960.
I found tech's response to this thread: https://volvoforums.com/m_41192/tm.htmbut wanted to make sure that it will be the same for a 93 960. I presume the rear brakes and rotors will be similar.
I plan on getting the OEM pads (or the Akebone ceramics...I hate brake dust (c: ) from FCPgroton. I have some spare silicon grease in my garage, do I need to specifically use the stuff at fcpgroton or will what I have work?
I have a feeling that my rotors are warped as the wheel shudders with hard braking. I thought I saw that Zimmerman rotors were the way to go.
I see that for the rear it says with or without IRS. What is IRS and how do I find out if I have it.
How difficult is an oil change? Is there a writeup for it that I missed?
Any idea where to get replacement speaker covers? I have 1 speaker working (left passenger) the others are dead and the speaker covers were broken. I was planning on getting new speakers from Crutchfield but I can not seem to find the speaker covers online, thoughts? (Part No.s 17638 RH, 17630 RH, and 17629 LH).
Lastly, for the moment, when driving over a bump, I get a sound like maybe the struts have gone bad (metallic clunk). How easy are replacing struts...and/or shocks...should that need to be done? Upon further reading, this appears that it might be the bushings. Any idea how to determine?
Thanks.
Clint
Thanks.
Clint
RE: New to Volvos, witha few questions
Thanks Tech. I figured out IRS about the same time as you posted. It was one of those DOH! moments. I look forward to working up underneath the car.
As for the oild change...i notice some od the service receipts mention a gasket...I'm used to popping the oil filter off, lipping the new filter with some oil and popping it back in...is there a gasket needed?
