Poor gas mileage....
Old Jan 30, 2013 | 05:11 PM
Milasin77's Avatar
Default Poor gas mileage....
My 960 runs well and all but seems like she likes here fuel a little to much. While I don't drive like granny, I am not doing burnouts or driving over aggressive. Mostly city driving but I'm getting a little over 100 miles per half tank. What gives?
Old Jan 30, 2013 | 05:14 PM
When was the last time the car was tuned up>
Old Jan 30, 2013 | 05:44 PM
Milasin77's Avatar
I have no clue since i just bought it. What are your thoughts on a tune up on this engine? So far I have only replaced the air filter and flame trap.
Old Jan 30, 2013 | 05:48 PM
I don't understand the question.
What year is it? I'd start by getting the real gas mileage. A few of those cars made the "cash for clunkers" list. I once got 548 miles on one tank and didn't run out. I was getting about 25 mpg around town. Fill up, rest the odo, drive till it's down to 1/4 tank, fill up again and run the numbers.
I after I got the true mileage I would go to work, starting with the plugs. Only use Volvo OEM single tip plugs. Do you have a CEL?
Old Jan 30, 2013 | 06:15 PM
Milasin77's Avatar
It's a 1995 960. Other then spark plugs what would you think might be the culprit for poor gas mileage?
Old Jan 30, 2013 | 06:51 PM
I'm not even sure you are getting poor gas mileage. Are you pumping 91+?
Old Jan 30, 2013 | 06:56 PM
Milasin77's Avatar
Yes, premium fuel all the time. I have a 20 gallon tank, that means I should get at least 200 miles with 1/2 tank for the 20 mpg (even that is poor I think for a 6 cylinder).
Old Jan 30, 2013 | 07:07 PM
Well, you can't always depend on a 18 year old fuel gauge. Lucky the thing moves at all.
Still didn't say if it has a CEL?
I use to own a '95.
chrispy960's Avatar
How does it idle? Is it smooth or rough? A rough idle could be a vacuum leak=poor gas mileage. Check your lines for leaks, they probably will be brittle. I'm a recent owner of a '97 960 with 240,000 miles on it and I'm still learning the car. Other than plugs and a air filter, there is not much to a tune up, you already have covered the flame trap. There are no wires or cap to worry about.
I'm getting around 19 mpg mixed driving and I haven't changed the plugs yet but there next on the list.
Old Jan 30, 2013 | 07:13 PM
Milasin77's Avatar
No CEL and yes I do have a vacuum leak for sure. I need to look into that just waiting for warmer days (no garage)
Old Feb 20, 2013 | 04:54 PM
Milasin77's Avatar
Default Gas mileage
I'm getting 15 mpg after testing.
Old Feb 21, 2013 | 09:37 AM
chrispy960's Avatar
Change out the plugs and find & correct the vacuum leak. Is it going into OD? What does the tach say at 55? Mine says 2000 when in OD going down the road. Any chance you have a stuck or hung up caliper?
geminigongju76
Mar 17, 2008 11:25 AM
postdoc99
Feb 8, 2007 08:00 PM
Swedishmeatballs
Dec 13, 2006 03:20 AM
Midnight_Caller
Oct 7, 2006 12:02 PM
phihong
Sep 20, 2006 12:49 PM
