How to test booster stages using a voltmeter. 1996 960.
Old Feb 25, 2013 | 04:11 PM
dksoutha's Avatar
Default How to test booster stages using a voltmeter. 1996 960.
Occasional misfire on #5 cylinder (PO305). Rewired the harness, replaced the coil, flushed the injectors, sorta checked for intake manifold leak (at least the bolts are tight), ran engine 5000+ RPM to clear exhaust valves, and changed the spark plugs.
...so I'm thinking it's one of the power stages. I've yanked the front one and have it sitting here on my desk. Can I test it using a voltmeter? If so, how? I think I've the correct stage for #5 cylinder, and I'd rather test it here than slog through the mud on my driveway trying to get at the rear stage for a swap.
What do you think?
1996 960.
Old Feb 25, 2013 | 04:41 PM
dksoutha's Avatar
Oh yeah - compressions test shows each cylinder at over 180 psi.
journeyforce
Apr 12, 2013 09:16 PM
laser99
Oct 22, 2011 11:05 AM
julia
Oct 3, 2009 09:05 PM
Rockytop
Feb 12, 2009 11:51 AM
keylargokeith
Mar 8, 2006 01:29 AM
