Hi again,I removed the lft rear door panel on my 1996, 960 in about 5 minutes without breaking anything.What I am trying to do now is raise the window all the way up and leave it until I can afford to fix it.Is there a way to disengage the motor.
Thanks for your help
Yes, what is wrong with it? If the motor is out you will have to take the motor loose, raise the window, re-secure the motor and it should stay up. If it rolls down but not up you may want to pull the plug on the motor.
