Issue with window regulator and window rollers
Old Feb 2, 2014 | 12:59 PM
reecesp1eces's Avatar
Default Issue with window regulator and window rollers
New here and just bought an 850 GLT 1993 not too long ago and I am having issues with the passenger front window.
I replaced the window regulator (pulled from a jukyard car) and the window rollers (bought from dealership). I get the ***** on the window regulator to lock into the window rollers but not tightly. They easily pop out even with the clips tightly seated. I have cranked on them with pliers and they are as seated as they can be without breaking the plastic roller.
The motor works fine as my it was tested and moves the arm without any issues.
Maybe the track or weather stripping?
Any help with this issue would be AWESOME as I am stumped.
I have worked on multiple cars before so I am not an idiot just need a guru to maybe shine some more light on the issue.
Thanks in advance.
Old Feb 2, 2014 | 01:26 PM
Those ***** are very hard to lock onto the rollers. They are also real hard to get out. Check another window roller to verify that you have them locked all the way in.
Old Feb 2, 2014 | 02:28 PM
Ok, I will re check them. Thank you.
Old Feb 2, 2014 | 04:20 PM
This worked thanks a ton. I thought I had then locked in but didn't want to break the plastic rollers. I cranked on them with channel locks and I heard them lock in all the way. Window works great. Thanks a million rspi! Its snowing outside now so I am glad to have a window that works!
Old Feb 2, 2014 | 08:44 PM
You are welcome. Those are the hardest I have ever worked on.
rspi
May 4, 2012 05:43 PM
artemis_f0wl
Apr 30, 2009 06:58 PM
Dads850
Aug 13, 2008 06:30 PM
aeabston
Oct 29, 2006 11:10 PM
xoneinax
Sep 14, 2006 10:28 PM
