PRV V6 Intake Manifold
Old Jul 6, 2009 | 11:41 PM
JP's Avatar
JP
Default PRV V6 Intake Manifold
Can anyone provide some sort of diagram or breakdown of the intake manifold and throttle body for my '88 760 GLE's PRV V6? I'm aiming to remove the intake manifold and as far as I can tell it's only held on with 4 small bolts? Is that correct?
TIA
Old Jul 7, 2009 | 12:35 AM
TIPSP's Avatar
Got Boost?
B280F right.....
Looks like four bolts to me.....
Old Jul 7, 2009 | 09:05 AM
JP's Avatar
JP
Hey, just what I was looking for. Thanks a lot man.
Old Jul 7, 2009 | 08:55 PM
JP's Avatar
JP
Well I got it off. Going to give it a good cleaning and new gaskets and such.
What is the black piece with the large thumbscrew on the bottom of the throttle body? It didn't have anything connected to it.
And what is this sensor? You can see where it goes into the block and then all the stripped insulation. There is one just like it on the other side directly across from it.
Here's the crank pos. sensor that Tech mentioned to me. You can see how stripped the insulation is.
Just some misc. pics
Old Jul 8, 2009 | 10:56 PM
TIPSP's Avatar
Got Boost?
Not sure... the black screw could be for the idle motor???
Old Jul 9, 2009 | 10:51 AM
brf0007's Avatar
"And what is this sensor? You can see where it goes into the block and then all the stripped insulation. There is one just like it on the other side directly across from it."
That sensor in the background under your hand with the stripped insulation is the knock sensor. Its basically a little black circle with a hole in the middle with a brass insert. I would suggest replacing both of them at the same time.
Old Jul 9, 2009 | 10:53 AM
brf0007's Avatar
also, while you have the intake off, you might want to replace those hoses, since you have easy access to them now. And I think that black screw is a plug in an unused vac line hole.
Old Jul 9, 2009 | 02:12 PM
JP's Avatar
JP
Awesome, thanks guys. Yes, I'm going to do a lot of cleaning and replacing of parts while I got it open. Can't wait to get it running again.
Thanks again.
Old Jul 9, 2009 | 02:17 PM
brf0007's Avatar
no problem
wavewright
Mar 22, 2020 02:10 PM
edolson
Jul 11, 2012 03:52 PM
edolson
Jul 11, 2012 01:24 PM
wmjodea3
Aug 9, 2009 07:40 PM
wavewright
Apr 23, 2005 12:57 PM
