searching for idle
Old Oct 25, 2006 | 05:14 PM
laroccajohnr's Avatar
Default searching for idle
My '92 965 is "searching" for an idle (ranging from near stall-500rpm- to 1700 rpm) after having had new timing belt, and tope end rebuild and new rear main seal.....anybody know why and how to fix?
Old Oct 26, 2006 | 03:41 PM
billofdurham's Avatar
Default RE: searching for idle
Check all the vacuum pipes for leaks or loose connections.
Old Oct 30, 2006 | 03:19 PM
drum's Avatar
Check O2 sensor.....?! Usually,if you have already looked for Vac. leaks that's the place where I would go.
Take care & good luck.
Phil
Old Nov 2, 2006 | 09:58 PM
Could also be a bad coolant temp sensor.
guest01
Mar 2, 2011 08:13 AM
Smedley
May 19, 2009 12:37 PM
b21f_ismyname
Sep 25, 2007 10:39 AM
jtests
Dec 21, 2005 12:43 AM
Lexus
Apr 28, 2005 12:50 AM
