Shifter light replacement
RE: Shifter light replacement
Its quite simple. All you need to do is carefully remove this plastic peice under the E-brake, there should be two hex-screws. Carefully pull the plastic back at the end of the unit, its only snapped in just make sure you dont break any of the clips. the light goes in awkwardly, its under the colum and requires small hands to pull it out. once youve done that you'll find that the bulb is soldereld into the socket. Get the bulb out and put and new one in either solder it or wire it up firmly. These are small bulbs and i found them at Radio Shack/ The Source. I changed all the burnt out lights on my S90.
xDread92x
07-21-2019 04:18 PM
sandraqu
12-24-2009 02:36 PM
phoenix_iii
01-11-2008 07:15 PM
