STRIPPED 12 MM BOLT - HOW TO REMOVE
Hi all. Over the weekend, I the jackass stripped the 12 mm bolt that holds the brake pads to the caliper. I did change the pads just by twisting it upright and sliding new pads in. However, when the time comes to replace the rotor, I will have to take that bolt out. Any ideas of how to proceed?
RE: STRIPPED 12 MM BOLT - HOW TO REMOVE
use an easy out. The name is generic and most people know what they are at Lowe's or Autozone. You drill a hole in the bolt andthen there is a reverse thread tool that you run in reverse in the hole and it removes the bolt. Go to auto parts store first they will be more heavy duty use.
