Expansion tank change and torx bolt that's stripped
Old Nov 5, 2008 | 02:26 PM
rmendoza's Avatar
Default Expansion tank change and torx bolt that's stripped
Hey everyone,
I have a 1998 V70 GLT, which is a 2WD Turbo 2.3, if I am not mistaken. I have a couple of questions. As I posted elsewhere, I think that my expansion tank and/or cap might be leaking or cracked; for a moment I was afraid that it could have been the head gasket or some other dire failure, but the car works like a charm, and there is no oil in the coolant or water in the engine; instead, I get a coolant odor inside the cabin now and then. I checked the carpeting to see if it was the heater core, but that wasn't the problem either.
I think that the problem is the expansion tank because there is evidence of dried coolant underneath it, and I can also hear a slight sibilant noise coming off the cap when the car is warm (I have to put my ear close to the expansion tank).
In any event, I was getting ready to change both the tank and cap, when I saw that many more-experienced forum members recommend also changing the thermostat at the same time. So my two questions are:
1. Which temperature thermostat do I get (FCP Groton's has three: 87, 92, and 107 degrees; I live in Tucson, Arizona which can get pretty damn hot in the summer, if that makes a difference).
2. I noticed that one of the torx bolts that hold the thermostat in place is kind of stripped (from previous owner). What is the recommended way of getting it out? Should I buy new torx bolts, or maybe hex bolts, to avoid this problem in the future? (Why Volvo would use torx heads with such large bolts is something I can't understand).
As usual, I thank you for your time and I appreciate your input.
P.S. I apologize for the long preface .
Old Nov 5, 2008 | 04:37 PM
rmendoza's Avatar
Default RE: Expansion tank change and torx bolt that's stripped
BUMP.
Old Nov 6, 2008 | 07:13 AM
You can get new screws from either Volvo which are now made better or just put Hex head screws in there.
Me I would buy new ones from Volvo. I like to keep things original like that.
Make sure you have a good brand Torxes socket and pray the screw will come right out.
I think the 87 might be the best way to go.
Old Nov 6, 2008 | 07:29 AM
rmendoza's Avatar
Thanks for the answer Tech.
What do I do if the screw is too stripped to come out, that is if I can't get it to turn with a torx socket? I have a set of those Craftsman bits that are supposed to hold on to stripped screws, but I don't want to do anything without being sure.
Old Nov 6, 2008 | 08:11 AM
That might work. Just Please becareful. The thermostat housings are known for breaking off the head if they are tapped top hard with a hammer and a chisel or something like that.
So tread lightly if you know what I mean.
good1662
Dec 26, 2014 12:05 AM
tobolate
Oct 13, 2011 12:24 PM
AnEskimo
Oct 5, 2010 09:13 AM
jnduke
Nov 3, 2008 08:55 PM
pawel
Sep 20, 2007 08:45 PM
