Stuck in P, no start
Hi all!
My Automatic selector stuck in P, wont move even with ignition and brake on. Also starter motor doesnt engage in start position, doesnt click or anything. same as when you try to start in D. Happened in middle of day when I turned it off for 5 mins, never happened before. Volvo 960 1992 2.9L.
Thanks in advance!
Thanks in advance!
Did you try pulling on the shift lock release?
To get the shifter out of park, apply the brake, turn the key to position 2, reach your index finger between the brush near "1" and pull up on the yellow latch. You should be able to shift out of park and into neutral. Maybe it will start then.
