Stuck with P0172 Code
Old Jul 29, 2011 | 05:21 PM
chuck101's Avatar
Default Stuck with P0172 Code
I have a 1996 Volvo 960 with a code of P0172. Check for vacuum leaks found some and repaired. Cleared codes drove 5 or 6 miles code came back. Does anyone have any ideas?
Old Jul 29, 2011 | 09:33 PM
Have to keep looking for split or damaged elbows. If that doesn't work, you may have leaks at the manifold.
Old Jul 30, 2011 | 10:02 AM
gabyman97596's Avatar
I had that code too when i first bought the car. you need to look closely at worn or broken vacuum lines near the throtlle area or yeah maybe it could be a leak in the manifold as RSPI said..
Old Jul 31, 2011 | 08:26 PM
960 rookie's Avatar
Hello-
I also have the same issue. No driveability problems, runs fine. Usually I would think that a vacuum leak would cause idle issues. Mine is steady at about 750rpm. Already cleaned MAF according to instructions on brickboard, but didn't help. Also have heard that there is an o-ring that seals the vacuum block on the lower part of the intake manifold. Sometimes that supposedly leaks. Seems random that that would be the issue, but I am going to try that as well. Read that it could be an intake manifold leak, but again- I would expect to notice run problems with any kind of vacuum leak, so I am a bit confused.
I have 120K on mine, and the O2 sensors have never been changed to my knowledge. I wonder if they could just be reading wrong? Is there a separate OBD code for a bad O2 sensor?
Old Jan 8, 2015 | 10:41 PM
Elite150's Avatar
Hi 960 Rookie - did you ever figure out what caused your P0172? I have a 97 960 and am getting the P0172. I have cleaned the MAF, i have looked for vacuum leaks but haven't found any), and am wondering what to focus on next. I heard somewhere else about that o-ring on the vacuum tree mounted to the intake. Any ideas on what helped you?
rmendoza
Mar 11, 2013 07:44 AM
philmac750
Engine & Internal
Sep 22, 2010 07:51 AM
rkent777
Feb 26, 2008 09:38 PM
Volvo850GLTOwner
Apr 13, 2007 09:28 PM
yellow95
Apr 23, 2006 01:54 PM
