Transmission fluid change?
Old Dec 25, 2005 | 04:51 PM
novablue69's Avatar
Default Transmission fluid change?
How hard is it to change the transmission fluid on a 760? What kind of fluid does it take?
New to volvos.
Thanks
Old Dec 26, 2005 | 11:51 AM
Default RE: Transmission fluid change?
Remove the drain plug and let it drain out. Then install new ATF Dextron III.
Old May 12, 2006 | 03:45 PM
my760's Avatar
IS there a filter to change and if so, do you recommend that too?
Old May 12, 2006 | 09:05 PM
You could change the filter if you really wanted to.
I have seen cars with 200,000 miles and never a filter change just the Fluid.
Stratoblaster
Sep 2, 2024 11:18 AM
AustinPower
Nov 11, 2008 07:43 AM
stonemason
Jan 12, 2007 09:44 PM
WHOISBIGMAN
Nov 11, 2006 02:37 PM
