turn signal staying lit
Old Jan 24, 2012 | 12:14 PM
yojohn's Avatar
Default turn signal staying lit
i have a 96,960 wagon the left turn signal stays lit but the right one works i have checked all the bulbs and they are fine would this be a problem with the turn signal relay and if so where is it located.?thanks for any suggestions you might have
Old Jan 26, 2012 | 05:11 AM
Henry10's Avatar
Is this front or rear light? You might have a problem with the grounds at the tailight, if it's the rear one.
Turn the flasher on, and see both lights flash the same way. Flasher Relay is in the engine compartment Fuse/relay box.
Old Jan 26, 2012 | 01:55 PM
Nine times out of 10 it's a bad bulb. You have to pull them out and inspect the contacts on them.
Old Jan 29, 2012 | 05:00 PM
yojohn's Avatar
ive checked all the bulbs and they are fine the problem corrected itself and the turn signals are working fine but as i was driving down the road it happened again right signal stays on left works but no 4 ways what is causing the problem
Old Jan 29, 2012 | 05:59 PM
J Brad's Avatar
Possibly the turn signal switch itself. I had this happen on the GM steering columns that I've installed in my Datsun & in my Scout. The contacts in the switch itself wore thin & broke off making contact when not on. I'm not sure of the design of the Volvo switch as I didn't pay attention to it when I had my issues with the ignition switch.
Old Jan 29, 2012 | 07:10 PM
So you pulled the bulbs and looked at each of them?
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
geo81mm
Jan 8, 2008 06:46 PM
mktmkt
Mar 7, 2006 10:08 PM
