turn signal stuck on
Old Feb 6, 2006 | 09:06 PM
my960's Avatar
Default turn signal stuck on
Hello! I have a 1996 960 and the the left turn signal is staying on when I flip the signal switch to turn left. The right signal flashes fine but now the left light is stuck on. Please let me know what to do. Thanks!!
Old Feb 11, 2006 | 04:57 PM
Default RE: turn signal stuck on
Check the front turn signal bulbs. The end contacts melt over time and melt together and cause both elements to stay on at the same time.
Old May 18, 2010 | 01:37 PM
s90guy's Avatar
I second the response above - I had the same issue recently due to the contacts on a bulb fusing together.
Old May 18, 2010 | 02:49 PM
Urban970's Avatar
I had the same problem. replaced the light bulb and problem went away.
Old May 22, 2010 | 09:47 PM
The older bulb causes all kinds of lighting issues. See this post: https://volvoforums.com/forum/showth...parking+lights
Old Sep 8, 2010 | 04:17 AM
elijah's Avatar
Default turn signal
That's quite an intriguing issue because many are encountering it. Try letting a mechanic check on it. Maybe there could be a faulty or loose wiring on the turn signal switch.
Old Sep 8, 2010 | 08:40 PM
Elijah, Junior Member, Wake up dude. We have it figured out and under control.
suckonthiscaravan
Dec 5, 2018 03:19 PM
shur
Feb 1, 2015 07:52 AM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
lounytoon
Nov 23, 2004 03:23 PM
