Two dio boxes? 92 960...
Old Nov 19, 2005 | 06:36 PM
twofourdee's Avatar
Default Two dio boxes? 92 960...
check engine light on 92 960 wgn, where do I start which box? I've pulled codes on 240's only. (only one box!) Also... E,S,W. lights by the gear shift were all flashing one at a time it went away on its own and now seems to be normal.
Old Nov 19, 2005 | 09:07 PM
Default RE: Two dio boxes? 92 960...
A1 is for the transmission A2 is for the fuel system.
Old Nov 21, 2005 | 03:01 PM
twofourdee's Avatar
got 214 code ignition rpm signal erractic. what does this mean?
Old Nov 21, 2005 | 09:35 PM
Most likely a bad Cam sensor.
Old Nov 28, 2005 | 02:54 PM
twofourdee's Avatar
location of cam sensor on 92 960 wgn?
Old Nov 28, 2005 | 09:11 PM
It is sucured to the back of the head on the drivers side. Feel and you should feel 2 torxes screws that hold it in.
SafetyNut2
Feb 8, 2015 12:10 AM
jbuck
Nov 16, 2011 05:48 PM
kevo409
Sep 22, 2009 08:57 AM
air force rascal
Mar 25, 2009 08:45 AM
air force rascal
Feb 20, 2009 10:04 PM
