120k mile maintenance?
Old Mar 21, 2008 | 11:52 AM
quarterdimenickel's Avatar
Default 120k mile maintenance?
Two questions.
1. How much should it cost to get this done by a dealer? If over $350, go straight to question 2.
2. What does this service entail? What does the dealership replace/inspect?
I apologize if this has been asked before.
Old Mar 21, 2008 | 06:35 PM
Default RE: 120k mile maintenance?
120k
Oil change
Fuel filter change
Air filter change
Spark plugs changed
Pollen filter changed(If it has one)
Coolant flush
Valve cleaner run through the engine(Maybe Dealers varry)
Maybe a few other things depending on Dealers.
Old Mar 21, 2008 | 07:07 PM
Alright.
I'm doing the oil tomorrow, replaced the air filter 3k miles ago, and don't have a pollen filter.
I got my gas tank replaced recently as well. What are the chances that they did the fuel filter as well?
And the valve cleaner. Is that some kind of fuel additive?
Old Mar 21, 2008 | 07:21 PM
I doubt they did the filter if you still have the receipt check it and see if they did.
The valve cleaner comes in a can and they run it into a vaccum port with the car running and it burns and burns all theBuild upoff the valves. But not all of them do it.
Some will try to sell you a injection flush.
You can get some sea foam and do it your self.
Old Mar 22, 2008 | 12:47 AM
JPN's Avatar
JPN
And double-check to make sure that the timing belt has been replaced at 70,000 miles or within the last 5 years.
JPN
Old Mar 22, 2008 | 10:01 AM
Psaboic's Avatar
If you are reasonably handy with tools, you can do the service yourself with the cost only being the parts and your time.
Glenn
Mahin Nadarajah
Nov 17, 2013 07:09 PM
tjh2a
Jan 15, 2009 05:16 PM
Ahmed
Jan 23, 2008 04:45 AM
Dainos
Jun 21, 2007 09:56 AM
MattS77
Jan 2, 2007 09:05 PM
