1993 850 burning coolant
Old Jul 10, 2007 | 04:32 PM
hillfolk's Avatar
Default 1993 850 burning coolant
Have any of you guys run into this? When the engine is cold it doesn't smoke from the exhaust. After it's warm, it definately smokes coolant from the exhaust. The engine oil is milky as well.
I'm guessing it's best case, a head gasket, or worst case, a cracked head or cylinder wall. Any guesses, or should I just start disassembly and hope for the best?
Thanks in advance,
Dave in Whistler, B.C.
Old Jul 11, 2007 | 02:40 AM
JPN's Avatar
JPN
Default RE: 1993 850 burning coolant
Hi Dave,
I can think of two possibilities:
1. Head gasket, as you noted.
2. Oil cooler line rupture in the radiator (not likely).
Unless the engine has had history of overheating, I don't believe there is a crack in the head or cylinder wall. I would do the following tests:
1. Cooling system pressure test.
2. Compression test.
These test would reveal pretty much all you need to know. If you have the tools & equipment, great but if you don't, have it tested at a dealer/shops that specialise in Swedish/European makes. Should you decide to have it done at a dealer, do not let them take advantage, as they like to sell you major parts.
I hope you can get it fixed.
JPN
Old Jul 11, 2007 | 10:07 AM
white out's Avatar
Sounds like a headgasket. Luckily on the i5 it isn't too much of a pita, everything is right on top.
Nick
Old Jul 12, 2007 | 08:49 AM
Psaboic's Avatar
Follow JPN's advice as he knows what he is talking about. I'm betting head gasket as well. I would not drive it until it is fixed for fear of overheating it.
Old Jul 12, 2007 | 09:48 AM
hillfolk's Avatar
Thanks for the input, guys. I picked the car up as a parts car, so am not driving it. I'll pursue the head gasket program as soon as I get the time.No way am I giving that job to a dealer!!!
thebull
Jan 3, 2012 05:43 PM
Nathan_92
Nov 21, 2011 08:37 PM
winston901
Nov 17, 2011 04:58 PM
joe71
May 7, 2011 09:39 AM
BriGuy
Mar 5, 2008 04:56 PM
