1993 Volvo 850 light problems
Old Aug 9, 2010 | 05:31 PM
Volvo850youngone's Avatar
Default 1993 Volvo 850 light problems
I have a 1993 850 and i have problems with the brake light on my left side, and i also have problems with the turning signal on the left side..im a beginner soo i was wondering what possible problems there could be. Any help is very much apppreicated.
P.s not only are the brakes and turning signal not working but the radio, and air conditioning arent working...maybe these could be connected some how? idk
Old Aug 10, 2010 | 06:27 AM
Old Aug 10, 2010 | 06:34 AM
1996850turbo's Avatar
youngone,
Check all the bulbs in the left rear tailight.
I was having problems with bulbs blowing often and weird issues..turned out the local parts place had a catalog with the WRONG bulbs listed for the car. (94' Turbo Sedan)
First place to look is the fuse block under the hood. Check each fuse to be good and of the correct amperage. It is tedious but I would go fuse by fuse.
Post more details as to radio/AC issue. DO you have the electronic climate control or manual?
Old Aug 10, 2010 | 06:45 AM
Here is the fuse info
* 1 - 15 Amp Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp Fuel Pump, Alarm System
* 3 - 10 Amp Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 5 - 30 Amp ECC Blower (Speed 4)
* 6 - 25 Amp Central Locking System, Alarm
* 7 - 15 Amp Audio System (Amplifier)
* 8 - 25 Amp Power Antenna, Trailer Connector
* 9 - 30 Amp ABS, Traction Control System
* 10 - Not Used (1993-95)
* 11 - 30 Amp Heated Rear Window & Side Mirrors
* 12 - 10 Amp Brake Lights
* 13 - 15 Amp Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp ABS, Traction Control System
* 15 - 10 Amp RADIO,Courtesy,Door Open,Trunk,Glove Box, Remote Control Central Locking , Oil Level Sensor, Seat Belt Reminder
* 16 - 30 Amp Accessories
* 17 - 10 Amp Key Reminder
* 18 - 25 Amp Heated Front Seats, Power Mirrors
* 19 - 15 Amp Left High Beam Headlight
* 20 - 15 Amp Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp Left Low Beam Headlight
* 22 - 15 Amp Right Low Beam Headlight
* 23 - 10 Amp Left Parking Light, License Light
* 24 - 10 Amp Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 27 - 15 Amp Back-Up Lights, Turn Signals
* 28 - 10 Amp Cruise Control, Heated Rear Window, Seat Belt Reminder Light,
, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp ABS, Traction Control System
* 30 - 10 Amp Cigarette Lighter
* 31 - 25 Amp ECC, ECC Blower (Speeds 1-3)
Old Aug 10, 2010 | 07:57 PM
I checked all the fuses with the manual and they were all in the correct spot except one for the radio...i put it in the correct place but it made no difference, and all the bulbs are fine, i even switched both the brake bulbs from the left and right side but it made no difference at well. What should be my next step?
Old Aug 10, 2010 | 11:04 PM
boxpin's Avatar
Does anything light on the left side?
Running lights
Brake lights
Backup lights
Turn signals
Rear fogs
If they are all out you may have lost your ground. Bottom line, your going to need a test light to really figure this out. Since the fuses are good and the bulbs are good.
Old Aug 11, 2010 | 03:40 PM
All the lights work on the left side except for the back brake lights and the front turning signal(i dont thinkk i told you that, Sorry!) Where should i get thissss test light?
Old Aug 11, 2010 | 03:56 PM
boxpin's Avatar
I am just clarifying, here is what you have...
1. The Rear left Brake lamp will not light when the brakes are pressed but the right side does light when the brakes are pressed.
2. The Front left turn signal will not flash when the left turn signal is engaged but the rear left turn signal does flash.
Old Aug 11, 2010 | 04:43 PM
Actually i just fixed the back left brake lights, after changing all the bulbs with new ones...and replacing the fuse, soooo now MY problem is the left turning signal, it will not turn on at all.
Old Aug 11, 2010 | 06:30 PM
Can you just tell me how to access the turning signal light and i will try to do it from there?
Old Aug 12, 2010 | 09:28 PM
Does anyone know.. Lol?
jws
Dec 30, 2011 08:09 PM
hotsh0t5
Feb 13, 2011 10:40 PM
Alex11
Apr 2, 2009 07:26 PM
Gator
Jan 20, 2009 08:21 AM
IL850
May 27, 2008 09:50 PM
