1994 850 non-turbo
Old Nov 9, 2023 | 03:50 AM
TurboGN86's Avatar
Default 1994 850 non-turbo
Good morning,
I have purchased a 94’ 850 from a neighbor in hopes of getting it running for my sister in law to use for a few months. It starts up, but idles very low and rough and shuts off, and sometimes it will idle very high (3k rpms+). I pulled the codes 113, 121, and 512. I ordered a new MAF but it doesn’t seems to have changed anything. It idles better without the MAF plugged in. I know the PVC system needs replacing due to the oil on the manifold by the fill cap. But parts have no arrived yet. I have fixed all of the vacuum leaks I could find which were quite a few.
before I play the parts swapping game, does anyone know some tests I can preform to narrow down what the culprit is before I spend too much money guessing?
have new MAF(is there a way to OHM this out?to test?)
have replaced the spark plugs
fixed vacuum leaks
any help is appreciated.
-Jeremy
Old Nov 9, 2023 | 03:43 PM
I'd start with some common tests before buying extra parts including a smoke test to look for the more difficult to find vacuum leaks, checking fuel pressure at the rail and measuring the ECT sensor's cold resistance. I'd also check the connector and wiring to the MAF - the 121 can mean the signal lead is grounded/shorted which can be the wiring, or the MAF unit.
Look for the RobertDIY videos on Youtube - I'm betting there is one for testing the MAF :-) .
Old Nov 10, 2023 | 11:37 AM
TurboGN86's Avatar
I unplugged the temp sensor and it runs and drives now. It will stumble occasionally and cut off but it is way smoother.
TANKWGN
Mar 21, 2016 09:22 PM
shur
Jun 22, 2015 03:20 PM
pitrow
Apr 4, 2014 09:53 PM
hall_gamma712
Dec 29, 2013 11:18 PM
AlanS
Feb 13, 2011 05:07 PM
