1994 radiator removal
Old Apr 13, 2008 | 10:19 AM
mtirei's Avatar
Default 1994 radiator removal
aloha,
i'm about to replace a radiator on a 1994 850 w/o turbo. does anyone know how to remove the transmissino lines going to the radiator? the new radiator doesn't have a hole that's threaded, it has a little neck that sticks out and looks like a coupling type. i'm trying to get this info before i start. any kind of info would be greatly appericated. Mahalo
Old Apr 13, 2008 | 10:25 AM
Default RE: 1994 radiator removal
They are spring clips that you need to open some to slide the lines out.
I use reverse snap ring pliers to open the clips.
Old Apr 13, 2008 | 05:40 PM
green850's Avatar
just a thought. i would replace those with some vise clamps when you put it back together, or you might end up like me and have your transline blow out while you're driving down the road. (no fun)
it's a pretty easy job, only takes an hour or so
HECTORPORTALUPPI
Mar 17, 2013 08:25 PM
mikeawd850
Nov 30, 2012 02:26 AM
HECTORPORTALUPPI
Mar 25, 2012 03:08 AM
frustrator-bolt
Dec 18, 2009 12:20 PM
