1995 850 sedan non turbo misfire
Old Oct 7, 2009 | 11:03 AM
rabare's Avatar
Default 1995 850 sedan non turbo misfire
Iam a neebie and need some advice.
Just p/u a 850 sedan non turbo.
The engine has a misfire at idle and appears to go away at speed..
I changed the plugs (autolites) and might have helped minimally..
Just looking for advice at what would cause this other than tune up parts..
I searched the forum and noticed stuff like MAF..Where is the MAF located?
Any sugestions would be appreciated..
Thanks in advanced, Rich
Old Oct 7, 2009 | 11:12 AM
gilber33's Avatar
MAF is located right after the intake box. I would try a full tune up before trying anything else. And would recommend only using OEM plugs. Also do plug wires and cap/rotor. Once all that's done and if you still have a misfire, go from there.
Old Oct 7, 2009 | 12:56 PM
blackbrick's Avatar
Is CEL on?
Pull codes. That may narrow witch cylinder is misfiring.
Ablorx
Jul 4, 2014 08:33 PM
taygarde
Nov 9, 2012 09:35 AM
cannebubbles
Aug 24, 2011 07:18 PM
Cardinals4505
Apr 15, 2010 09:47 AM
cadidj
Apr 21, 2007 02:20 PM
