1995 850 turbo a/c reshim question
Old Jun 27, 2010 | 09:44 PM
vetalbig's Avatar
Default 1995 850 turbo a/c reshim question
would it be possible to reshim A/C clutch on 850 turbo without pulling whole compressor assembly out?
Old Jun 27, 2010 | 10:07 PM
Yes it is possible but it is a pain. You have to support the motor and drop the subframe down then work the compressor down enough to get it apart.
I have done about 30 of them. It can be done but it is a pain. You also loosen the bracket on the dryer so you can slide the dryer some to get the compressor to where you can work on it.
Old Jun 27, 2010 | 10:28 PM
vetalbig's Avatar
damit, sounds horrible but has to be done soon, summer is hot in texas, i assume removing the whole assembly would be even more of a pain? bread clip idea just doesnt sound right
Thank you
Old Jun 27, 2010 | 10:32 PM
Well that might be a little easier. If you remove the entire compressor you can remove the dryer as well. Then the compressor will fit through where the dryer was.
I am not a fan of the bread clip idea either!
Old Jun 27, 2010 | 10:40 PM
vetalbig's Avatar
trying to find step by step instructions on a/c compressor removal, any idea?
Old Jun 27, 2010 | 10:44 PM
I have not made one on here yet. I am not sure where there is one either sorry.
Old Jun 27, 2010 | 10:48 PM
vetalbig's Avatar
ok thank you Tech!
taygarde
Nov 9, 2012 09:35 AM
dlaxdal
Sep 29, 2011 02:02 PM
calidist
Oct 17, 2010 06:54 AM
carmanj
Dec 7, 2008 12:31 AM
pittpan2005
Mar 15, 2008 08:09 PM
