1995 850 turbo radiator
Old Jun 3, 2009 | 06:29 PM
dlaxdal's Avatar
Default 1995 850 turbo radiator
What is the difference between $205 Nissen Rad and $295 Behr Rad.
Old Jun 3, 2009 | 07:44 PM
I would go with the Nissen one IMO Nissen is way better.
Old Jun 3, 2009 | 08:37 PM
dlaxdal's Avatar
Thank you for the input. How do you tell if your water pump is working fine without doing pressure test? The temperature would rise would it not or just the pressure in the radiator. I did not change it when I went and changed timing belt and pulleys
Old Jun 3, 2009 | 08:46 PM
If you see flow in the coolant bottle then the water pump should be fine.
I had a S80 yesterday that the impeller was broke on and it kept pushing coolant out of the bottle.
Old Jun 3, 2009 | 09:02 PM
dlaxdal's Avatar
What kind of flow? Not exactly sure. If the pump is not working, would it cause the pressure to go up and the temp also?
Old Jun 5, 2009 | 09:27 PM
Yes it would. But the heater hoses to the firewall would also be cool and not heat coming out of the dash.
Old Jun 6, 2009 | 10:35 AM
dlaxdal's Avatar
Thanks
mikeawd850
Nov 30, 2012 02:26 AM
taygarde
Nov 9, 2012 09:35 AM
Supra850
Aug 25, 2012 11:03 AM
gabanja05
Jun 15, 2011 12:12 AM
carmanj
Dec 7, 2008 12:31 AM
